Is a LogicBoard Upgrade possible
Now using a beautiful black A1181 2GHz Core Duo MacBook. Like to know if a 2GHz or better Core 2 Duo Logic Board (A1278) can be built in instead of the original one. Thanks
Es esta una buena pregunta?
Its not a direct fit, Other items in the Macbook need to plug into the logic board, such as the fan, inverter cable, these have different connections between the 2 Models. Generally not worth the money unless parts are super cheap or free. for the price of the logic board, fans, cables, etc. you could probably find a whole used Macbook.
Fue útil esta respuesta?
Didn't realize A1278 was for a unibody macbook - will not work at all.
As Matthewfrey said well, they are unfortunately incompatible. Actually, there isn't a single connector on the board that is compatible, so you would be rebuilding an A1178 machine from parts (which is so much more expensive than just purchasing a complete machine).
Sorry!
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 2,332
