Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Un gran teléfono inteligente de LG, lanzado en otoño de 2014. El LG G3 (D855) cuenta con una pantalla IPS Quad HD y una cámara de 13 megapíxeles.
My phone is restarting when using camera
I am using lg g3. When i use camera frequently it restrart or or being off. And not going to switch on with power button until i replace battery. What is the problem. What will i do now. Thanks
Es esta una buena pregunta?
Puntuación 2
2 comentarios
since LG G3 has android 6 it is no more possible to use other than original batteries. i know that sounds wired. i ve tested it
- de
I've found the exact same problem. Even when I use an alternative operating system (Cyanogenmod 13), if I have a cheap knock-off battery, even if it is charged up, using the camera will cause the phone to reboot. Using an OEM battery, or a higher quality battery, at least, seems to be the solution.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hi,
You could also try turning off your phone's GPS and WiFi functions (if you do not need them at the time and if they're on, as they use a lot of power, especially GPS) and see if your battery lasts longer. Also does the camera have a 'flash' option that maybe you can turn on/off depending on whether you need it. This also drains the battery.
Does it do this when you have the charger connected and switched on?
If not, then your battery is probably starting to fail and needs to be replaced.
Fue útil esta respuesta?
Puntuación 3
Restart the LG G4, this could fix camera failed problem. Hold the “Power” button and the “Home” button at the same time for 7 seconds until the phone turns off and vibrates. Go to Settings, open the Application manager and then go to the Camera app. Select on Force stop, clear data and clear cache. For more assistant support please check LG G3 Manual.
Puntuación 1
Añadir tu respuesta
ziauddin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 27
Todo El Tiempo: 16,199
