Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4267 Ver todo
GPS not accurate / lagging
My iPhone 6 is out of warranty and I would like to know if there is a part I can replace to get my GPS working again.
I have restored the phone and reset all network settings, I think I have tried everything in my power and can confirm it is a hardware issue.
Apple also looked at it and confirmed it is a hardware issue but I am out of warranty.
If anyone has had any experience replacing any parts to get GPS working again, I would be grateful if you could help me.
Problems experienced...
When using both Wifi and 4G data, applications using GPS (Google Maps, Apple Maps etc) my location cannot be pinpointed, when using Google maps for navigation, due to inaccuracy, it is unusable.
Thank you!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
3 Respuestas
Respuesta Más Útil
In addition to an inacurate GPS I had Bluetooth and WiFi weak. I read the thread GPS & Bluetooth work sporadically and I followed the guide step by step ;after WiFi Antenna Signal Flex Cable Ribbon replacing all problems were solved. I posted photos to show you the root cause in my case.
Fue útil esta respuesta?
Calificación 1
Hi
Maybe you have trouble with the GPS IC, you need to find someone that can fix problem like this.
Hope this help
Calificación 0
Comentarios:
Thanks for responding, what is a GPS IC
por
See this thread for the fix!
GPS & Bluetooth work sporadically.
Calificación 0
Añadir tu respuesta
Z N estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 13
Últimos 7 Días: 81
Últimos 30 Días: 383
Todo El Tiempo: 9,195
