Saltar al contenido principal
Furby era un juguete robótico electrónico popular que se asemejaba a una criatura parecida a un hámster/búho que pasó por un período de ser un juguete "imprescindible" después de su lanzamiento en la temporada navideña de 1998, con ventas continuas hasta 2000. Furbies vendió 1,8 millones de unidades en 1998, 14 millones de unidades en 1999, y en total en sus tres años de producción original, Furbies vendió más de 40 millones de unidades.
Preguntas 85 Ver todo
Furby Boom's not moving much and goes to sleep after 1 minute
My daughter's Furby just started to make this cracking noise with every word it says. Also the Furby's moving very quietly and not moving back and forward (at all).
Usually when the Furby goes to sleep, it will bend forward. Also the its ears (sometimes) are not moving forward when going to sleep.
When the Furby is awake, it will last like 1 minute and its eyes will light off (and will go to sleep). It will only wake up if I shake it well.
I also noticed that will not react fast/properly when touching him.
The reset (or the change of personality mode which only went right once) won't help.
I kindly ask for help. I also speak Dutch, Spanish and Italian.
Thanx!
Es esta una buena pregunta?
Puntuación 8
11 comentarios
I have the same problem.
- de
Have you solved the problem so far? I haven't yet.
- de
I am having this issue too. I skinned Furby, safely without scissors like I see many using, I found out the Furby I bought used had an issue. His red wire which is attached to his tummy had come out of its socket and there was pieces of the wire still in it. Furby does not move his stomach, ears, mouth or eyes for me and powers down after a few short seconds. Fresh batteries were not the issue as the ones I used were brand new and worked in other devices. If someone can solve this problem I will be eternally grateful to get my pink, orange and blue Furby Boom up and running again.
- de
Hi, i have the same problem and i tried also refresh button and new batteries..it is still the same, Do you have some contact to service? thanks
- de
same here!! I got 1 furby to work, but the other, Thunderstruck, keep doing this.
- de
Mostrar 6 comentarios más
Agregar un comentario
6 Respuestas
Solución Elegida
Hi!
The small 6V brushless DC motor went wrong. I had the same issue.
You can replace it with one from a PC DVD reader (this is the door opener motor). Shaft is smaller but it's ok, diameter is good.
I used a disassembly instruction from here:
Disassembly
Be careful with clips, use a small screwdriver and push the fixing inner parts. With this you can avoid the damage.
You need a solder iron as well to replace electronic part from DC motor.
Now my daughter's Furby is working again!
Fue útil esta respuesta?
Puntuación 5
5 comentarios:
Hi szabot79 , Do you mean that I gotta replace the small rotor theeth-wheel? From the Disassembly process, could you please tell me until which step (picture) i gotta go and where (picture from this link) I can find the rotor wheel? Thanx
- de
Hello! I have a Furby Boom 2013, this comment is valid for this type.
You have to replace the motor itself, not rotor part, so you have to do every step above to reach motor.
Picture link for motor part.
http://3.bp.blogspot.com/-tl_hdlvDHd8/UU...
Link for original source (russian):
http://4pda.ru/forum/lofiversion/index.p...
- de
Szabot79, How did you get the replacement motor? And what does the motor look like? Thanks!!
- de
It wasn't until after I had completely disassembled, repaired, and reassembled the furbacca that i realized how correct the answer above is. There are so many misleading (unintentionally) suggestions out there.
As for the motor, it is about one inch diameter, half inch thick, and shaped like a drum. I also got mine out of a DVD player. The motor opens and closes the dvd drawer. I don't know why i happened to have an unneeded dvd player either. It was out of a computer.
Also, disassembly and reassembly is a pain. Be gentle and know there is a right way even if it seems impossible. The motor will need to be unsoldered from it's previous connectors and then the circuit board from the furby needs to be unsoldered from the bad motor and soldered onto the "new" motor.
The ears on furbacca had to be removed in two pieces on both sides. I slid a very small screwdriver between the rubbery part and the hard plastic part until the rubbery part could be pulled off. Then there is a tab on the hard plastic part to take that off. I didn't bother to reglue it afterwards. it's pretty snug and i may have to do this again. I told the kids not to yank on the ears.
- de
Hello everybody,
I confirm the engine problem.
In my case the engine was running, but the ears and eyelids were out of sync.
I disassembled the gearbox and put the eyes in the closed position and the ears forward.
After reassembly and ... the furby was repaired.
In French
Bonjour tout le monde,
je confirme le probleme du moteur .
Dans mon cas le moteur fonctionnait, mais les oreilles et paupieres etait désyncronise.
J'ai démonté la boite d'engrenage et mis les yeux en position fermée et les oreilles vers l'avant.
Apres remontage et ... le furby etait réparer.
Thank you , Merci beaucoup
- de
i know the awnser exactly, i am a furby collector and i own over 80 and the problem with your furby is that its frozen.. sadly this can't be fixed unless you take off the fur and see if the power wire is attatched properly, the little plug is in properly or to fix it you will have to add new battries, change the motor and transitors Hope this was helpful.
Puntuación 1
2 comentarios:
Hello. Do you maybe have a tutorial video for us all please? Cheers.
- de
A good guide could help lots of Furby fans!
- de
Mine had that too
My furbacca didnt move but the sound was on
I removed his fur and i was trying to see the problem
The problem was the thingy (gear) that lets the furby move
It didnt have that much oill
And i put some and it worked !
How did I remove the fur?
Click here : https://www.youtube.com/watch?v=kAARcn2c...
Its in Russsian sorry but it will help you
Puntuación 1
Hi there! I don't know much about Furbies, but I found an FAQ. I assume you tried the "refresh" button? You may also try to replace the batteries, you just need a screwdriver and 4 AA batteries.
Good luck =(
Puntuación 0
2 comentarios:
seriosly? tell how
- de
Corroded battery terminal are the fault
- de
Well... hi guys i have crystal furby and it doesn't seems well to i've try to and it works. You just need to refresh the furby and leave the old furby mind and replace a new battery. if you want to fill up your furby identity you may install on your gadget furby boom app. How to restart, below the furby (on the buttom of furby) you see small button next to the battery you press that for 3-5 sec. comment me if it works or not THX ;3
Puntuación 0
2 comentarios:
How do you do these things? Any links?
- de
I did it but still not working.
- de
hi! i think there is no solution to this problem unfortunately, my furby did it today unless you would like to take the whole furby apart you do that then but otherwise the furby is stuck like that. (the refresh button dosnt work fyi) I've tried the refresh, hard reset and changing the battires.
Puntuación 0
1 comentario:
The battery terminal May be corroded
- de
Añadir tu respuesta
Ciro Morante estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 13
Ultimos 30 días: 68
Todo El Tiempo: 35,536
