Saltar al contenido principal
Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
Preguntas 236 Ver todo
Microphone not working after charging port replacement
Hello,
I have changed the microphone / charging port on my S6 Edge. Now the microphone is very fuzzy and people can barely hear me when i'm talking over the phone. Everything else is working fine. The repair went smoothly as I've fixed quite a few of these before.
Has anyone else had this problem? I'm guessing it could be different rev. numbers on the part. Although I binned the old one and cant find out which version it was.
Any help will be greatly appreciated.
Es esta una buena pregunta?
Puntuación 2
1 comentario
So you've taken apart a few of these? Where did you order replacement adhesive from?
- de
Agregar un comentario
4 Respuestas
Solución Elegida
If it's not OEM, it's common for the replacement headphone ports/mic to be bad.
Just get another replacement, chances are it will be better.
Fue útil esta respuesta?
Puntuación 3
1 comentario:
I'll give that a go and let yous know. Thanks for the quick reply.
- de
OK so after trying 2 different charging ports / microphones. The problem was still there. I tried one more from another supplier and it worked fine. Seems like there are quite a few faulty ones going around. Thanks again
Puntuación 0
1 comentario:
Can you please help me, my s6 edge plus stops working the mic, what flex cable should i buy? regards
- de
Hey did you ever fix your mic issue. I have used the earrings ...no good factory reset.. No good... Took Sim out and no good.. Ugh help me somebody please
Puntuación 0
1 comentario:
Yes, he did.
"OK so after trying 2 different charging ports / microphones. The problem was still there. I tried one more from another supplier and it worked fine. Seems like there are quite a few faulty ones going around. Thanks again"
- de
The same problem so after trying 4 different charging ports / microphones. The problem was still there.
Puntuación 0
Añadir tu respuesta
Peter N estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 29
Todo El Tiempo: 4,078
