This LG Tribute smartphone is identified by model number LS660. The device was released in October of 2014 and runs on the Android operating system.
Preguntas 23 Ver todo
Why won't my phone charge?
When I plug my phone in it doesn't recognize that it is charging or connected.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
3 Respuestas
Gus-
If your phone is plugged in to charge but does not recognize a connection then the first thing I would do is test the chord. Either use your chord to try charging another device or use a different chord to charge your device. If your chord is working then my second suggestion would be to clean out the charging port with compressed air. If your chord is good and your port is clean then I would say you might need to replace your charging port. Take a look at the LG Tribute Troubleshooting page.
Fue útil esta respuesta?
Calificación 0
Try removing the battery, then plugging in the cord. After at least 30 seconds, add the battery with the cord stil l in. It should take a while, but it will charge.
Calificación 0
I had that problem i changed my charger and blow into the pert where charger goes mine was going crazy its fine now
Calificación 0
Añadir tu respuesta
Gustav Wolter estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 43
Últimos 30 Días: 233
Todo El Tiempo: 2,855
