Saltar al contenido principal
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
Preguntas 149 Ver todo
help with wifi hardware
hey
i would like to know the wifi hardware on the hoc one m7
as its very week to detect the wifi
to connect i need to be just few cm near the router or it will not work thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
4 comentarios:
Hi,
Have you tried connecting to a different router? Does it 'pick' up other networks (I know that you cannot connect to them). Are you trying to connect to 2.4GHz or 5GHz WiFi?
- de
hey
it works only when am in few cm from the router
my phone had been prepared so i think some thing not okey on the hardware
maybe not correctly attached
its on auto mode so its both are selection 2.4 and 5 ghz
- de
Hi,
Can you detect other routers or not?
- de
yes but only if am near (less than 1 meter )
- de
Agregar un comentario
1 Respuesta
hey it works only when am in few cm from the router my phone had been prepared so i think some thing not okey on the hardware maybe not correctly attached its on auto mode so its both are selection 2.4 and 5 ghz
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Hi,
Looks like you are right. Maybe you should take it back to the repairer and get them to check their work.
- de
Añadir tu respuesta
attiouim estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 94
