The ProScan PLT7223G Tablet, manufactured by Curtis International, is a basic Wi-Fi enabled tablet that is intended for personal or professional use.
Preguntas 8 Ver todo
Why won't my ProScan Tablet turn on?
Whenever I go and press my power button the ProScan tablet still won't turn on.
-I have charged the tablet numerous times and it still won't turn on.
-I have attempted to do a factory reset but the screen won't turn blue and the options menu doesn't pop up.
Please let me know if it can be a problem with the motherboard or the battery it self.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Agregar un comentario
1 Respuesta
Solución Elegida
According to your description, there are several possibility to caused your device cannot turn on. First, try to find similar charger and charge the device again. The charge may faulty. Next, if the charging cord works, you may have a faulty battery. If the problem still there, it may because a broken motherboard. And you to use guide to replace it. For more information to solve the device wont't turn on problems, please check ProScan Will Not Turn On
Fue útil esta respuesta?
Calificación 0
Comentarios:
Mine comes on says proscan looks good and then start to blink and flash what could be the problem
por
Mine is doing that too.
por
Añadir tu respuesta
Daniel Hernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 31
Últimos 30 Días: 157
Todo El Tiempo: 6,121
