Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Preguntas 162 Ver todo
Why my 2DS does not open?
I have a 2DS and when I power it on the blue light turns on but the screen still remains black. After some seconds it makes a wierd noise and turns off completely. My brother says that it has been exposed to water . Any ideas on how to fix it?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
This is a complete guide for teardown and troubleshooting and can guide you through your fix
Nintendo 2DS Repair
Hope this helps
Fue útil esta respuesta?
Puntuación 2
Put in rice for a day
Puntuación -2
Comentarios:
Rice is a food not a tool
- de
But if it gets wet it will soak up all the water
- de
@Cozy Rozema, Rice is absolutely useless. It will not remove all humidity, it will not prevent corrosion, it will not remove liquid between components and it will not prevent short circuits. Using Rice as a desiccant is the equivalent of doing nothing.
- de
You're Both Right - Rice is a fine opening move for consumer water removal, but OldTurkey has a point, it's not going to solve your problems; disassembly will be required.
- de
@alinorne Kevin - Rice as a desiccant is an old wives tale. Even if you boil it, it only soaks up 2X. Unboiled all it does is make a mess. Your voracity as an answer giver is at stake here, do the research!
- de
Mostrar 2 comentarios más
Añadir tu respuesta
John Hatzis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 265
