Repair guides for Android cell phones manufactured by LG.
Preguntas 1972 Ver todo
it says unfortunatley, system UI has stopped
I am using a LG pro max and the screen shows unfortunately, system UI has stopped
I am unable to use the device
Thank You
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
i cant even get the phone to do a factory reset. the error message never goes away. i click ok when it pops up but within 5 second its back. i have an lg g4. i need help. i can't do anything on this phone, i can't even shut it off with the back power button. i have have to dismantle phone and remove battery.
por
hard reset your phone by pressing off button and volume key down
por
Agregar un comentario
7 Respuestas
Respuesta Más Útil
My other cell phones UI stopped working and it won't work when I hold the power button and the volume key down as it told me to do.
Fue útil esta respuesta?
Calificación 2
Comentarios:
my phone kept syaing that and it finally shut down and wont turn back on
Calificación 1
If it is rooted and you do not know what you are doing, you might have deleted an odex file that patches that. Otherwise the systemui settings are corrupt and you might have to do a factory reset.
Calificación 0
Comentarios:
I did a factory reset and nothing changed
por
I can not find a device called "LG Pro Max". are you sure that is the correct name?
por
me either i did factory reset and nothing change
por
por
I have had this problem too. The error message "Unfortunately, System UI has stopped" pops up around every five minutes, and I can only access the first 5% of my phone. The battery charges fine, but the phone itself doesn't allow me to use the device because of the error message.
Calificación 0
Comentarios:
Abert, did you find the solution for that problem? I have exactly that problem now! Thank you
por
I use a lg Phoenix 2 and when I start up the phone it says unfortunately, system ui has stopped. I can't do anything on the phone. How do I fix it.
Calificación 0
When the measage pops up hold the power button for complete shut down then click ok then quickly power of the phone and wait for the phone to eathier cool down or just turn it back on and try it
Calificación 0
Comentarios:
I tried that and when turned back on it did same thing
por
I'm having the same issue with my LG Pride I purchased from TextNow. The phone has been doing a slow crash on me. I should've sent it in for replacement as 3 days after i received it i stopped it in dog water. Placed in rice for 12 hours and it worked fine, though edge of screen stayed a light blue. My memory on the phone was very limited and I hadn 't yet gotten an sd card so I kept getting warning messages about "some functions may not work”. Anyway hoping someone finds the answer because I can no longer use the phone and all my information and pictures which I didn't sync are now unattainable.
Calificación 0
Añadir tu respuesta
imtiyaz khan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 21
Últimos 7 Días: 105
Últimos 30 Días: 639
Todo El Tiempo: 13,419
