How do I repair xbox 360's red ring of death?
How do I repair the XBOX 360's red ring of death?
Es esta una buena pregunta?
There have been many questions asked about this. Use the search feature in Answers to search some of the earlier discussions. "red ring" or "three red lights" might be good choices for search terms. Here's one of the longer discussions on here.
Fue útil esta respuesta?
The bolt fix which clamps the heatsinks to the main board is a horrible way to repair your game console. Get it reflowed or reballed using a proper heat compound and repair method and you will get many months of use from it. Use the bolt fix and the unit will no longer be a successful candidate for reflow or reball and the flex will break traces on your board when you send it for repair.
Be careful with only recommending just one site on all of your answers. It does come very close to spamming, even so your answers are correct....The fix here may not be agreeable to you but that is just your opinion. It has worked for many others.
ALL his answers have had the same recommendation resource.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 2,162
