The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Preguntas 688 Ver todo
My PS3's HDMI port isn't working
My PS3's HDMI port stopped working and I had to switch to the Component cables. It was working perfectly and one day it just stopped. The TV seems to be getting a blank signal since it doesn't say no signal. I've also tried switching the HDMI to another port on the TV
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Comentarios:
Did broke the connector of the hdmi jack when you plug in the hdmi cable to the port?
it easy to break it since this is soldered on the motherboard like a power jack on the laptop motherboard.
por
Well i had the same problem and im still trying to fix mine to also i just tried everything :/
por
Agregar un comentario
3 Respuestas
Solución Elegida
Did you check with another HDMI cable? That would be my next move if I were you.
Fue útil esta respuesta?
Calificación 3
Comentarios:
por
If it turns out that the cable is not the problem, you can try resetting your video card. Hold down the power button for about 15 seconds. It will turn on and then back off again, with a couple of beeps.
Calificación 1
Comentarios:
I did this to get it to switch to component
por
I have had my USB and HdMI ports serviced at a repair company called VideoGame911. They did it really fast. I had it back in less then a week.
Calificación 0
Añadir tu respuesta
Jorge Fernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 3
Últimos 7 Días: 24
Últimos 30 Días: 86
Todo El Tiempo: 16,646
