Wifi button greyed out
I replaced the screen and after awhile the wifi button cannot be activated, should I replace the motherboard?
Es esta una buena pregunta?
No, you will probably just have to replace the wifi antennas, which is probably what got ripped when you opened the device.
Fue útil esta respuesta?
I agree, everyone who has worked on iPads enjoyed one day or another a teared up wifi antenna ;)
Yup. Happens when you put the pick too far in on the right side.
What I'm afraid of is the wireless controller being messed up. That would be a board-level repair.
Sounds like you didnt reseat the wifi module properly, or as you were dismantling it you cracked part of the ribbon cable.Check , reseat, or replace the wifi module.
I assume you tried doing the cold reset and switching in amd out of airplane mode, this is usually a fix for airplay too when that “greys” out.Hope this helps.
Replace your wifi antenna iPad 3 Wi-Fi Wi-Fi Antenna Replacement
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 211
