Saltar al contenido principal
A touchscreen smartphone made by LG released in September 2013 with the model number VS980.
Preguntas 185 Ver todo
once I lock it I cant unlock it
Hello,
I have Lg G2 D802 version. I turn it on but once i lock it i cant unlock it anymore. When i press power button backlights turns on for 2-3 sec and turns off. Only way to use phone is to restart it.
I have tryed to put new OS, new LCD assembly, 2 new battery.
Any solution?
Sheers
UPDATE:
replace USB PORT AUDIO JACK HEADPHONE PLUG FLEX PCB
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Hi Nikola,
Has your update fixed the problem?
If not, it is likely the proximity sensor. Have you opened the phone up before it started, replaced screen?
Do the following tests.
Simple:
- take the phone next to a very strong light (for just a couple of seconds, you don't want to melt it) and press the power button. Does the phone wake up?
Medium Complexity (be very careful not to fry the motherboard or screen by static - do at your own risk)
- turn off the phone
- take off the back cover and the top motherboard cover.
- carefully remove the proximity sensor from its nest, so that the sensors are facing the light
- very carefully turn on the phone back on
- once the phone is on, put it to sleep and try to wake it up again either with tapping screen or power button.
- turn off the phone (completely power it down)
- reassemble
If either of these work, your proximity sensor just needs to be wiggled a little in its nest so that it is picking up light. Make sure it has it's rubber 'glove' still on.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Nikola Santek estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 74
