Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1418 / finales de 2012 / procesador Core i5 de 2.7 y 2.9 GHz o Core i7 de 3.1 GHz
No Power - won't turn on
My computer just shut down and won't power back on. Won't do anything. It is like it isn't even plugged in. I have tried a different power cord. I tried holding the power button. I have unplugged everything from the usb ports.
I have opened up the computer - I am wondering where the diagnostic led lights are. I am wondering if it is the power supply board - it does look like some wiring melted - although its not black or burnt...
Imagen
Es esta una buena pregunta?
Puntuación 2
2 comentarios
The diagnostic LEDs are to the right of the RAM slots.
- de
Could be a bad power supply unit
- de
Agregar un comentario
3 Respuestas
Solución Elegida
Be sure to discharge the big capacitors and handle it with one hand. I may be mistaken, but that looks like where the transformer bridges from the AC side to DC side. It will have very high voltage there. If that's exposed wire in the pic then it is likely indicating a problem. The end of one wire looks yellowish too, as if it may have been hot. All of your symptoms point to a bad power supply. About 70% of the time I see these it's the Power Supply, so I'd definitely put my money there.
Fue útil esta respuesta?
Puntuación 2
The diagnostic lights are to the right of the RAM slots.
Puntuación 2
The diagnostic lights are under the RAM slots. See picture
Imagen
Puntuación 1
Añadir tu respuesta
Lesli KeepSimple estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 18
Todo El Tiempo: 1,857
