The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
Preguntas 410 Ver todo
Machine turns on, no signal / video output?
I have an xbox 360 that has never red-ringed and turns on just fine, but refuses to work with any TV I try to plug it into. I have plugged another xbox 360 into the same cables and TV, but when I plug this one in the TV reads "No Signal."
Any thoughts??
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 8
Agregar un comentario
5 Respuestas
Solución Elegida
Make sure that the component cable is set to whatever input you have the cables plugged into. For example, if you are using the component connection, RED-GREEN-BLUE and then WHITE-RED for your audio, make sure the switch is set to HDTV. If you are using standard connection, YELLOW-WHITE-RED, then make sure it is set to TV.
If this still doesn't work, try a different pair of video cables and if the same results are coming up, you will need to have the board repaired. You can not just replace the motherboard either or you will not be able to play games on the system, make sure to have the actual board repaired.
Yes there are ways to repair the board out there but board repairs are different from replacing it. If you don't use the right equipment, you pose a greater risk of damaging the board more than it is already. It's best to have the system repaired by a professional that provides a warranty on their work.
Fue útil esta respuesta?
Calificación 3
on the video cable, there is a switch that changes between hdtv and standard definition tv. make sure it is on the right one.
Calificación 2
This is caused by a heat up of the chips internally and you will need to stop this. The actual chip that is overheating here is the scaler chip or the display chip on the back of the Xbox 360.
Calificación 2
https://www.youtube.com/watch?v=EvFq9-py...
Calificación 0
If nothing works wrap a blanket around the Xbox while still it's on it will get very hot when it shut it off An back on with hdmi cable on it should work I had to do it for mine
Calificación 0
Añadir tu respuesta
Hal estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 22
Últimos 7 Días: 154
Últimos 30 Días: 793
Todo El Tiempo: 53,394
