Saltar al contenido principal
La línea de laptops iBook de Apple fue planeada para el consumidor y los mercados educativos. La línea de iBook consta del iBook G3 Clamshell, G3 12", G3 14", G4 12", y G4 14".
Preguntas 825 Ver todo
Need a 45w power adaptor and a DC board for iBook G4
Would like to install myself. Do you use a conventional Allen key to open back? Does the installation of the board require and soldering?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hi! No soldering is required, just follow this guide.
And here's the DC-in board
And the AC adapter
Please note, the DC-in and guide are for the 12" G4. If you have a 14" G4, you'll just need to look up the 14" version of the DC-in (which is longer), and use the 14" guide.
You can use an allen wrench, although torx will fit a little tighter, but either work. The procedure is pretty substantial, but the iFixit guide will get you through it.
Thanks, and good luck!
Fue útil esta respuesta?
Puntuación 2
it's not exactly clear which model iBook you have but regardless the repair guide for your particular model will list the tools you will need. typically aside from regular screwdrivers you may need a Torx screwdriver.
to replace the DC board you do not need to solder anything - there are connectors joining it to the main logic board
Puntuación 0
Añadir tu respuesta
George estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 846
