Saltar al contenido principal
Lanzado en 2013, este portátil multifunción forma parte de la serie de portátiles Satellite C50. Tiene una pantalla de visualización de 15,6" y viene con Windows 8.
Preguntas 12 Ver todo
Why won't my laptop's screen go on
It was one day when my laptop's battery was low at around 10% until I used it until 7% then I closed it.When I put it in charging it gave me a black screen then I tried to repair it but it's screen spot going on
Es esta una buena pregunta?
Puntuación -1
Agregar un comentario
1 Respuesta
Solución Elegida
Make sure you have a charge and that your power supply is functioning What do you mean by"it's screen spot going on".A little more info on what you mean would help in the mean time A static discharge is also an option . Unplug the machine and pull the battery then hold down the power button for a full 60 seconds then release and do it again then put the battery back in plug in the laptop and try to reboot.. Hope this helps
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Isaac Rego estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 181
