Installed new rear camera but it's still not working!?
I followed the guide from ifixit to install a new rear camera after a minor fall crack the edge of the screen and the camera no longer functioned, but after a new camera and a new battery the problem persists!
The front camera works fine.
The rear camera is black. The flash does not function. There is a caution "overheating - wait for battery to cool" warning and the battery does overheat quite easily.
I have checked all the connections which seem fine, and not sure how to diagnose.
Help please!?
Es esta una buena pregunta?
If the battery is heating when this device is functioning then there's a short . When you installed the camera was there some sort of installation between the care and the camera or insulation at the connectors. There is a short probably against the care
- de Jimfixer
I think you mean case right, the aluminum body? I will reconnect all today but it all snapped into place fine before. I wondered if the camera was bad.
I have a multimeter. Can I check for a short on the case somehow? Is there a fix or would it require soldering?
- de dylanemcfarlane
