Why won't the motor stop running when plugged in?
One day after normal use of blending, I pushed down the button to blend and then it never stopped running unless unlplugged.
I have disassembled the top motor portion and about a 1/4" diameter and 1/2" heigh spring fell out, but nothing else seemed obviously amiss.
Maybe I haven't found the right spot where the spring belongs and it had just worked loose, but I can't find a manual that shows where the spring should go.
I have tried putting the spring where the top piece contacts the bottom piece near the bottom side and near the top middle directly on the motor shaft. No luck.
Es esta una buena pregunta?
