Why is my jbl charge 2 without sound
After charging completely my jbl charge 2 i turned on, i connected without any problem but the sound doesn't comes out. waiting for prompt response.
Thank You
Es esta una buena pregunta?
Thank You
I have the same problem,:
- my jbl charge 2 is fully charged
- I switch it on without problem and lights of Power button and sounds level are all ON
=> it doesn't make any "beep" sounds when it turns on as before
- I have no problem to pair it with my iPhone, it is recognized by Airplay
=> I do not get any sound when I play music on my Smartphone
=> I do not get any sound if I connect using a stereo audio cable connected to the 3.5mm aux input as per jayeff question
I have opened the casing but do not see any special damaged items in it... do I have to change the speakers? Do I have to change the electronic card? Any suggestions or guidelines ?
Thanks for your prompt response and advises.
Fue útil esta respuesta?
My charge 2 plus has been fully charged but now havnt any beep sound or music sound
any one else can Help me ??
Hello, I took mine apart and the resistor is cracked. Can you provide any information on how you replaced yours? The video that is in Russian appears that the user was able to glue it back on.
Thanks in advance for your time!
I have the same problem...what can do ?.. firstly what is the problem?
Did y'all try to connect and play in a very low volume???
My JBL Charge 2 still play in a very low volume but when I try to increase it, the sound stops suddenly.
Does anybody can help me, pls?
Took mine apart, was able to determine the problem was the said resistor, my challenge here in Nigeria is getting a replacement...
I to had the same issue and fixed my resistor with hot glue just like he did. Works like new now
My JBL is acting funny. Red light blinking, static, goes on & off. When I hook it up with a cable does the same thing.
Ultimas 24 horas: 3
Ultimos 7 días: 9
Ultimos 30 días: 33
Todo El Tiempo: 35,923
8 comentarios
Hi,
Do you get any sound if you connect using a stereo audio cable connected to the 3.5mm aux input?
- de jayeff
https://www.youtube.com/watch?v=Ok4yYOZg... This is the guide (in Russian). It shows the reason of your problem
- de varggot
Thanks a lot Varggot, this was the problem. The resistor was broken and I fixed it !
- de David Bertet
i want to TearnDown my Charge2+ but i think this is not my problem ☹️how can i see exactly wrong and problem
- de SalehEVO
My jbl charge 2 + volume doesn't go up, I can hear music playing but it's very low, it only works on Bluetooth and the when I play from the Aux there is no sound at all. It is fully charged and I even reset it. Can someone please help me?!
- de tahahaji52
Mostrar 3 comentarios más
