Rechargeable wireless Bluetooth headphones, sold as an accessory to the Sony PS3. Features virtual 7.1 surround sound. Model No. CECHYA-0080
Preguntas 10 Ver todo
I lost my usb, what I do?
where i can buy another? and, can? please help me. thanks
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 8
Comentarios:
Where can I find a replacement USB dongle?
por
MerkMark, ebay
por
Hi I bought a geoteck sc-1 controller but the dongle was faulty and doesn't work where can I get a replacement one
por
Agregar un comentario
9 Respuestas
Respuesta Más Útil
I see this topic come up at least once a week and every single time someone is telling the person the USB dongle is unique to each unit and can't be replaced. This is completely incorrect. I know all these people are just repeating what they have been told/read, but it's wrong.
Once you find a replacement USB dongle, do the following to pair it with your set.
1 Connect the wireless adaptor to a PlayStation system or other powered USB port.
2 Insert a small pin or similar object into the hole surrounding the reset button in the wireless adaptor, and push in for at least one second.
3 On the headset, hold down the MUTE button and the VSS button.
4 While still holding down the MUTE button and the VSS button, slide the power switch to position 1 or 2.
Fue útil esta respuesta?
Calificación 11
Comentarios:
Suren's instructions are for the newer wireless gold headset, not the CHECHYA-0800 model that this section covers.
por
just did it on my headset thats the oldest version and it works fine
por
Was that the 0080 version you treid if so what dongle did you use
por
thanks alot i just bought a dongle at a game store for $20 and i wouldnt of gotten it to work with out your help
por
Will this work on the playstation platinum headset if I get a new dongle I also have 2-3 dongles from all the gold headsets I had can I pair the platinum with a gold dongle or a new platinum dongle?
por
Mostrar 2 comentarios más
For the OP's actual question, you can get a USB dongle from Ebay.
https://www.ebay.com/sch/i.html?_from=R4...
Calificación 0
Comentarios:
yes but the model # must be CECHYA-OO81 ON THE dongle reciever
por
Guys i have (CECHYA-0083)
Would it work??
Where can i found usb? The one in ebay CECHYA-0082)
Thanks in advance
por
I have a CECHYA-0080 model with no dongle, will a newer dongle work with this?
Calificación 0
You Can Absolutely buy a new one where that is going to be your effort, you can try CraigsList, LetGo, Amazon, Ebay or games stores like eb games ect.. when you get your new dongle reciever for your playstation headphones there is a little hole with a button inside on the dongle try using a sim card tray key works the best and there will also be another hole on the headset right where it says volume on the headset just after the letter E there will be another identical hole there too push that too then it will search for new reciever
Calificación 0
Yes it worked fine for my CECHYA-0082 headset
Thanks
Calificación 0
Have you found the answer yet because I lost mine to
Calificación 0
hi do you know can i conect two pair headset to one dongle?
Calificación 0
Comentarios:
i'm pretty sure thats a no, only company i know that remotely does that is logitech with there unifying software that can connect up too 8 devices but that was a little off topic to your question.
por
You get another dongle that's the same model look around it for a tiny pin hole put a piece of led (this can break inside and ruin the receiver) or something else small enough have the headset off while you put this it the hole when you did that hold the button on the headset until you are paired!
Update (06/23/2018)
Buy a new receiver of the same model number (cechya-0080 headset and receiver). Find the tiny pinhole on the receiver. Get a pin or (not recommended) piece of led, etc.
Have the headset off.
Stick the object your using in this hole then hold the headset on button until you see the paired message on ps3/ps4. Congratulations you have your headset connected.
Calificación 0
Does anyone know where to get an affordable dongle for the cechya-0080 headset? And according to the thread discussions, it can be set up and used if I purchase one? Thanks!
Calificación 0
Añadir tu respuesta
lveitia estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 37
Últimos 7 Días: 258
Últimos 30 Días: 1,441
Todo El Tiempo: 29,597
