Saltar al contenido principal
Announced in March 2015 and released April 10, 2015, the Galaxy S6 Edge is the curved-screen version of Samsung's newest flagship smartphone.
Preguntas 237 Ver todo
Water in main card
Hi!
I've got water damage to my main card. it is possible replacement for this item?
i also getting a red line on the screen sometimes cost of the water damage i think..
Can acid bath help?
thank you.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Clean ever connection with a soft toothbrush dipped in99% isopropal alcohol . As well clean the logic board use a 99% isopropal alcohol for all cleaning. now is the time to start drying out the phone. Set the screen in a desiccant or silica gel leave it in for several day moving it from time to time to get the max effect from the desiccant . use a blow dryer on a low heat setting to dry the rest of the phone. replace the battery with a new one consider the old ones done. Clean again with isopropal alcohol let dry and when you think everything is clean and dry reassemble the phone (make sure to clean the contacts on the screen after removing from the desiccant). Once you've reassembled the phone its time to power it on. Hold your breath and hope for the best
By the way rice is for cooking not drying
Fue útil esta respuesta?
Puntuación 6
4 comentarios:
Ok. Great!
so only brush and do not take out logic board?
put the phone whit every table and screen into silica gel?
This is great reading ..
thanx agai
- de
I take out logic boards and clean both sides
- de
Pretty good instructions. Do you watch Louis? :D
- de
Yeah, louis fine type :D
- de
Añadir tu respuesta
fredrikfurseth estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 114
