Saltar al contenido principal
Reparar información en unidades de disco o discos duros. Los discos duros son dispositivos magnéticos de almacenamiento de datos. Se utilizan en la mayoría de las computadoras de escritorio, portátiles y servidores debido a su bajo costo y alta densidad de datos.
Preguntas 139 Ver todo
Harddrive being detected as an external but cannot see any files
Cannot see any files after being detected including windows files...
Es esta una buena pregunta?
Puntuación -1
3 comentarios
There's not enough information here to give you an answer.
- de
The harddrive was first being used as an internal harddrive, after some time it failed n could not be detected. As an external its being detected but i cannot see any files in it including the win files! Hope u understand now
I want to knw on how to retrieve the information!
- de
Help me with a recovery software tht works!
- de
Agregar un comentario
1 Respuesta
Solución Elegida
You used a a failing hard drive to store data? Data recovery services are outlandishly expensive. You could get an identical drive and try switching the boards. But you really need to think before you act.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
No it was in perfect working condition before n used to work. But suddenly it has failed
- de
Añadir tu respuesta
Murtaza Kadibhai estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 94
