Saltar al contenido principal
La Kenmore Elite HE3 es una lavadora de Kenmore.
Preguntas 668 Ver todo
Help concerning Door Boot Seal
I have a Kenmore He3t Washer. The door boot seal has a small tear and I am getting some water leaking out of the unit during the wash cycle. I should also mention that my Kenmore dryer is stacked on top of the washer.
My question is, can the small tear in the existing boot seal somehow be repaired? If not, in order to install a new boot seal, do I have to remove the dryer from the top of the unit or can a new boot seal be installed by accessing only the front the washer?
Es esta una buena pregunta?
Puntuación 2
3 comentarios
Please give us your model number so the part can be looked up.
- de
The model number is 110 44832 202
- de
Thank you very much. One last question,. Although the video says you need to remove the top panel of the washer, I didn't really understand why. It looks to me like you can get access to everything you need just by removing the front panel. That way I don't need to worry about removing the dryer from the top of the washer. Am I missing something?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Door Boot Seal
RepairClinic Item # 1027300
Door Boot Seal - Part # 1027300 Mfg Part # 8182119
Watch Video:
Skill Level: Skill Level
This part fits your Washing Machine
Washing machine door boot. If the washer is leaking, the door boot may have a tear in it. Overloading the washer is the most common cause for a torn door boot.
OEM Part - Manufacturer #8182119
Related Items:
Boot Seal Retaining Ring #1059565
Boot Seal Retaining Ring #1059566
Cleaner #1373065
http://www.repairclinic.com/Shop-For-Par...
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
John estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 45
Todo El Tiempo: 3,203
