Saltar al contenido principal
Aquí puedes consultar guías de reparación para MacBook.
Preguntas 3783 Ver todo
Keyboard connector lock on logic board broke
While changing my hard drive, my hand accidentally touched the keyboard ribbon connector cable on the logic board and the locking mechanism broke. The connector is intact just the locking bar broke off and the laptop is now unable to power up. :( I need help figuring out what to do. I wanna avoid buying a new logic board. and yeah the cable seems fine with no dents or marks
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
I suppose you're talking about a unibody MB here. This is a very dire situation indeed. You can try to place the cable in the socket and secure it with tape or similar. Take something that doesn't melt at 60 degree, it can get hot in a laptop.
Good luck!
Fue útil esta respuesta?
Puntuación 3
1 comentario:
That's what I'd try. Here is a link to a source of the tape Apple uses. +
http://www.uline.com/BL_6407/Kapton-Tape...
- de
Hi Lexzahir,
Sorry I am late to your repair but am posting this, hopefully to assist others with the same problem.
Im not familiar with Apple products in general, but by your description, it sounds like it may be similar to a connector problem I had on a Sony laptop keyboard connector.
I had snapped off the little plastic tab latch that holds in the keyboard ribbon cable on a laptop, and found an easy way to fix it.
The same problem can occur on may different devices, such as CD players, laptop keyboard connectors, camera ribbon cable connectors, etc.
If you break off this little tab, the ribbon cable is not held in at all, and just falls out of the connector.
On the off chance that you have the same type of problem, check out my YouTube video I had posted last year. Not sure what is wrong with your connector. If it is the same problem, you can easily fix it in a few minutes.
Easy Ribbon Cable Connector Fix, Repair.
https://www.youtube.com/watch?v=bhaeKdUl...
Puntuación 0
3 comentarios:
looks like your video is no longer available.
- de
I checked it a few minutes ago, it is there.
- de
The link in the original post seems to have been cut off when it was posted.
After posting this, I can see that it is STILL cut off,
So I'll past the address portion after youtube.com so that it is clear
/watch?v=bhaeKdUltz8
Thanks,
Alex
- de
Añadir tu respuesta
lexzahir estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 12
Todo El Tiempo: 2,839
