What is the avrage cost of head gasket replacement
What is an average cost for head gasket repair of 2008 Chevy Equinox?
Es esta una buena pregunta?
The cost of repair depends on what needs to be done . If you get it done at the dealers or a local shop . If you get it done right or half assed. the tear down and rebuild will take about 6 to 10 hrs the head gasket kit will cost roughly 100 for gaskets but you really should have the heads machined unless you want to do it again later. Then theres do you need to replace the bearings in the bottom end. if the head gasket had caused coolant to leak into the oil you will need to rebuild the bottom end . If your oil looks like chocolate milk dont risk it it will fail in short order.If the oil was contaminated I would look for another motor. It would likely be cheaper than the rebuild. So throwing a number out there would be hard 600 on the low end 2500 on the high end depending on what has to be done.
Fue útil esta respuesta?
we have a 2005 chevy equinox lt with a 6 cyl 3.4 lt engine that needs to either have the head gasket replaced or at worst case the heads replaced and all of the gaskets as well. how much should this run ? how many hours of labor to do both jobs ? trying to decide if it is worth it or not.
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 26
Todo El Tiempo: 6,994
