El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3640 Ver todo
My iPhone 5s won't turn on, charge or connect to itunes
Hello, I got an old iPhone 5s last Thursday and it felt completely fine, the volume buttons wouldn't work sometime and the touch ID didn't work but it was still working fine, I was told it was in a protective case most of the time and I bought one for it straight away because my luck with phones is awful! I went out last Saturday night and came home and taken my phone out of it's protective case and attempted to charge it, it wasn't accepting any charge into it unless I really squeezed the charger up to it, so I decided to turn my phone off and I assumed it was just my moms charger was rubbish and collected mine the next day. No charger is working in it, the phone won't even turn on or show any signs of life in it. I've tried all the tips of holding down the power and home button at the same time, removing any debris that may be inside of the charging port and none of them have worked. The screen on the phone does pop in and out a tiny bit when there is pressure on it so that could be a problem. I need to know how to repair it myself or what needs doing by a technician if needs be. I have had multiple iPhone's this year and I am not willing to splash out cash on another phone, or even pay for a big repair I've honestly spent way to much money on them, help would be immensely appreciated!
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
You need a new lightning dock and you need an apple charger
Here's parts
iPhone 5s Lightning Connector and Headphone Jack
Here's labor
iPhone 5s Lightning Connector Replacement
As far as the screen popping up, could still be a factory display assembly. I've seen it happen before. Either way, you're more than likely going to have to replace it down the road. You do however need to be careful with that part, while disassembling the phone
Imagen iPhone 5s Lightning Connector and Headphone Jack
Producto
$29.99
Fue útil esta respuesta?
Calificación 3
Comentarios:
If I went into a store what would I need to tell them to repair?
por
The.. Lightning dock. It's the assembly I pointed out above. It has the charger port, the speaker, the headphone jack, some other junk
por
check if there is any dirt stuck in the lightning jack somethime there is some cloth dust stuck in these port
Calificación 0
Añadir tu respuesta
Jordan Nelson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 13
Últimos 30 Días: 90
Todo El Tiempo: 1,663
