Why is my phone over heating? only using one app!
started happing after i used a cheap portable charger.
Es esta una buena pregunta?
Hi there, You should stop using that cheap charger. It may have damaged your battery or some of the components on your motherboard. I say try get a brand new battery and see if that helps.
Fue útil esta respuesta?
Your battery and some of the components of your motherboard is damaged .
reason is the CHEAP CHARGER . cheap chargers make Voltage Swims in m.b components .
please replace your battery and try to use fabric samsung charger .
if it didn't work it means that your m.b is damaged and u must replace it :(
Arad_SB
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 67
