How to chamge motherboard
need to replace motherboard. how can i do? where i can purches motherboard? how much cost of motherboard
Es esta una buena pregunta?
Replacing a PC’s motherboard takes time and more than a little sweat, especially if you've never done it before. You could trip on any number of little hurdles during the motherboard removal and installation process. But don’t worry! We’ll help you get through the process as quickly and painlessly as possible.
Let’s start with why you’d even want or need to replace your motherboard. (If you’re simply looking for instructions on how to install a motherboard in a new PC, scroll down a bit.)
Sometimes components fail. Motherboards are no exception. I’ve fried many a motherboard thanks to bad BIOS flashes and failing or flaky power supplies. Things happen, and sometimes those things can irreparably damage your motherboard.
But replacing a motherboard is a lot of work. Before you start, you want to make very, very sure that your motherboard is broken. Step one is using one of these handy troubleshooting flow charts to make sure your motherboard is truly the culprit. Assuming your motherboard is confirmed dead, it’s time to consider a replacement.
Fue útil esta respuesta?
It seems there is no much store sell motherboard, you'd better repair it in the professional repair shop.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 92
