Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Partes y herramientas
Wireless router released October 2007, model number is WGR614v9.
Preguntas 18 Ver todo
The router wont power on
My Netgear router WGR614 won't power on, it was working fine earlier. I moved it to a new apartment and now it won't work. I've tried unplugging it and plugging it back in and still nothing.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
Kits para Nintendo Switch
Una solución rápida para volver al juego
Comprar kits de Switch
2 Respuestas
Solución Elegida
try the rest button small pinsized hole in near ports
Fue útil esta respuesta?
Puntuación 3
Sounds like a power supply problem.
1: Replace the power adapter with one equivalent to the original to eliminate a bad adapter.
2: Open the adapter to see if you have swollen capacitors (cap) , if so replace it or them.
3: Open the router carefully and make sure you don't have swollen caps. If so, replace them. You can tell a swollen or bad cap by looking at the top of them. It should be flat. If the tops are round or bubbled , place them. Also look for burnt or deformed components and place them .
Let me know if that helps to narrow down the problem . And let me know if the problem still exists .
Puntuación 0
Añadir tu respuesta
Billy Roach estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 12
Ultimos 7 días: 89
Ultimos 30 días: 317
Todo El Tiempo: 5,061
