Released June 2012, Model A1278. Intel processor with Turbo Boost, Up to 512 MB DDR5 Video RAM
Preguntas 1011 Ver todo
New hard drive doesn't show up in disk utility?
A couple of days ago, my hard drive, stopped working (flashing question mark). I bought a new 1tb sshd from Seagate, and have tried to boot using this, and a memory stick i have with os x yosemite, this does not work. The new drive doesn't show up in disk utility once i boot on the memory stick. Anyone know wether it's the sata cable, the firmware, or anything else that causes the problem, and a solution?
Thank you :)
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
This series had a lot of problems with the SATA cable, I would start there.
This is such a common problem IFIXIT has a special guide just for it: MacBook Pro 13" Unibody Mid 2012 Hard Drive Cable Replacement. Here is the cable you need: MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable.
After you order the part you can also check the systems firmware following this Apple T/N: About EFI and SMC firmware updates for Intel-based Mac computers. Yosemite & El Capitan both upgrade the firmware so it might be newer than what Apple has listed here.
Imagen MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Producto
$44.99
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Petter Thorsen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 14
Todo El Tiempo: 1,760
