Saltar al contenido principal
Una consola de videojuegos producida por Sony Computer Entertainment, anunciada por primera vez el 20 de febrero, en 2013 y lanzada el 15 de noviembre en 2013.
Preguntas 944 Ver todo
ps4 wont use update on usb
I replaced the motherboard/optical drive on my ps4 and now its asking for system update using a usb for version 3.00 or later. I formatted my usb for FAT32 and downloaded the update from the plastation.com website and put it in the file format PS4->UPDATE->PS4UPDATE.PUP
it gave error code (CE-35952-4)
this didn''t work. Then I tried the exfat format with the same file path, and that did not fix the problem either. Both were attempted in safe mode, I have tried all of the other options from the safe mode menu and still the system will not load properly.
Please help and thank you for doing so.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 5
Comentarios:
I finally got it to update after using your advice and a 2 gig usb. For whatever reason the ps4 wont update using a usb with greater than 4kb block size. Go figure. Thank you for your help!
por
Great news! I'm glad you got it working!
por
If replacing a HDD into the PS4, as TronicsFix stated, do not download the top update file. You need to download the file under System Software Tab at the bottom of the page (~800 mbs). Kept experiencing the same problem as the PS4 said get latest update file, which I already had in my FAT32 formatted usb drive. Thank you TronicsFix
por
This was the REAL fix...what a life saver... she's awesome☺
https://youtu.be/S6CVYhBYMDw
por
I just got myself a new 2tb hard drive for my PlayStation 4 and I got a USB flash drive that's been formatted so I could download the update. I didn't download the first link at the top of the page but I downloaded the other one that's 800mb and made a file PS4->UPDATE-> "PS4UPDATE.PUP" and out my PS4 in safe mode and tried initializing PS4 software and it says update not found! Need help ASAP!
por
Mostrar 6 comentarios más
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
5 Respuestas
Solución Elegida
There is a good chance that you have the wrong update file loaded onto your drive. When you are on Sony's website the first one you come to is not the right file (It's for the most current UPDATE...you need the entire system software)...the file you need is located near the bottom of the page. When you get close to the bottom of the page you'll see this: "Perform a New Installation of the System Software"
That's the file that you need. Just be sure to reformat your drive and follow the rest of the instructions to a T.
I hope this helps. Post back here if you still need more help.
Good luck!
Fue útil esta respuesta?
Calificación 14
Comentarios:
I've done all of that and I still get the same error
por
thanks so much. after OEM hard drive fail, I installed a 2T internal. I kept downloading the wrong file. As soon as I grabbed the 900K file for full install I was back in business. THANKS!
por
I created an account just to thank you for this post. You're the best!
por
I used a 2 Gb Usb rather than an 8Gb one and it worked fine thanks guys
Calificación 2
Comentarios:
Great news! I'm glad you got it working.
por
After doing this mine goes to system software update screen and shoots error code Su-30679-5 any ideas?
por
does the usb have to be a 3.0 usb
por
Wat kind USB do u need im having same problem I've got 32 gig USB still not working help plz
Calificación 0
can i use a 4gb? cause I've tried a 32, 16 and under a 1gb but the first two didnt work and the last one had to little storage.
Calificación 0
Comentarios:
I tried a USB drive with 2 GB and mine doesn't get recognized by the PS4 either. Does the flash drive need to be a specific USB version? I believe this one is 2.0, but I can't be sure.
por
formatting to FAT32 and not EXFAT plus downloading the 980MB file again did the trick for me ((:
Calificación 0
Añadir tu respuesta
unitunitglue estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 72
Últimos 7 Días: 570
Últimos 30 Días: 2,618
Todo El Tiempo: 58,819
