Saltar al contenido principal
La serie Aspire 5315 presenta un procesador móvil Intel Celeron y un chipset Intel Mobile GL960 Express
Preguntas 13 Ver todo
Why doesn't my laptop start up?
Cannot turn on my computer!
Hi!
Cannot turn on this laptop.
If I plug it in with battery in - status LEDs are indicated as:
Power/Suspend LED - lights up red;
Battery Charge/Discharge LED - bliks red;
If I plug it in with battery out - status LEDs are off;
When I try to turn computer on in both cases Power/Suspend LED turns on green for a half second as soon as I release the power button and I can hear as ventilator span on, but after half second it all turns down and returns to previous positions.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
Having the same challenge with my acer laptop. What's the issue with acer gadgets?
- de
Agregar un comentario
3 Respuestas
After looking into this a little bit, here's the first thing I would try.
Remove the battery from the laptop, and unplug the AC power cable from the laptop.
Hold down the power button on the laptop for 1 minute, and then let go.
Reinstall the battery, and plug the laptop into AC power.
Try to start laptop now.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Hi Greg,
I tried your solution, but unfortunately it didn't help, the laptop still won't start up.
Ted
- de
Take your computer to a store, let the professionals to do the trick.
Puntuación 0
I Once I removed the image cable from my laptop and re-inserted it correctly, the laptop suddenly turned off completely and it does not turn on without battery or with battery,Even the charger does not turn on And it has no symptoms and is off
Puntuación 0
Añadir tu respuesta
Ted Herba estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 302
