Saltar al contenido principal
La segunda generación del iPad con modelos Wi-Fi, GSM y CDMA. Algunos modelos se actualizaron antes del iPad 3. La reparación es difícil y requiere calor y palanca.
Preguntas 729 Ver todo
Pregunta Cerrada
Screen goes off when the back is tapped
I have an ipad2 wifi, works fine except if you tap it in certain places the screen goes off and you have to press the lock button to wake it up again.
no visible damage on the chassis but asking the owner (he's asked me to fix it) says it goes off if you tap near the ribbon cable area (left hand side bottom half) mostly.
i suspect a faulty ribbon cable to lcd but also think it could be a faulty lock button shorting?
any ideas?
thanks
dyfed
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
I would probably say the same thing; those LCD cables seem to want to fall off to no end.
Not sure if you've ruled this out already, but it's good to cover all bases: It might be the auto-lock feature. If you can consistently replicate the problem though, with auto-lock off, I'd just remove the digitizer and reconnect the LCD cables.
Fue útil esta respuesta?
Puntuación 0
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 41
