Saltar al contenido principal
La segunda generación del iPad con modelos Wi-Fi, GSM y CDMA. Algunos modelos se actualizaron antes del iPad 3. La reparación es difícil y requiere calor y palanca.
Preguntas 730 Ver todo
iPad 2 black screen
My iPad 2 screen went black... i see it's turn on... back light but no image. Hard reset won't do nothing. When i do a screen capture i momentarly see my screen a little...
I tried to to hit it a little like i saw in some messages but it's doing nothing. Any help please?
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
3 Respuestas
Solución Elegida
Yeah, your backlights out. Not super big on iPads. But, I think you just need to replace the LCD.
Reemplazo del panel frontal del iPad 2 Wi-Fi EMC 2415
iPad 2 LCD
Imagen de iPad 2 LCD
Producto
iPad 2 LCD
$59.99
Fue útil esta respuesta?
Puntuación 2
It's likely that the iPad will need to have the lcd cable reconnected. Sometimes smacking the back doesn't work. With the proper instructions And patience you can open the iPad and do this. Be sure to power the iPad off first though. Just hold the power button for about 5-10 seconds then swipe not the screen towards the top where slide to turn off would be. You should see the backlight dim slightly then turn off.
Follow the ifixit guide to open an iPad 2, and you'll be good to go.
Puntuación 2
Didn't work, followed the procedure and did what was required with no changes. Still a dark screen.
Puntuación 0
Añadir tu respuesta
martinesabourin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 4
Todo El Tiempo: 802
