Fourth generation Samsung Android tablets. Released in 2014.
Preguntas 342 Ver todo
My tablet won't turn on, even after charging for hours
How can I get my tablet to turn on? I tried the factory reset, but still no luck.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 3
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Hello Jenny,
Hope below steps will help you to turn on the Tab back
  • Disconnect the charger
  • Press and hold the power button 25 Sec
  • Connect the charger while pressing the power key
if above steps not works for you check the charger whether it works or not
Fue útil esta respuesta?
Calificación 1
Having a similar issue with a tablet I've been given to repair.
Customer having troubles with it turning on and charging, even tried disconnecting and reconnecting the battery and he said that worked temporarily.
I've plugged in a battery tester on it, and the current going into the tablet through the charging port is inconsistent, meaning that the charging port is most likely damaged.
In order to fix this issue, the charging port can be replaced so that the battery can be charged properly again.
Calificación 1
Añadir tu respuesta
Jenny estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 842
