Saltar al contenido principal
Guías de reparación y desmontaje y soporte para la línea de cámaras digitales SLR de Canon, incluida la serie Eos.
Preguntas 759 Ver todo
Why does it say "card cannot be accessed"when my camera's on?
Yesterday i went to charge my camera battery. This morning it was fully charged and when i went to put it into the camera and turned it on, it said "card cannot be accessed reinsert/change the card or format card with camera." I tried switching the SD card to all the ones i've used previously, including the one i used the day before. I don't know if there is a problem with my SD port of my camera, or the actual SD cards i have.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
It probbably means there is something wrong with The sd port
Fue útil esta respuesta?
Puntuación 0
Hi, if you do not have any important data on you SD card, you can format your SD card to fix the problem. Here are two ways to format the SD card:
Format memory card with Windows File Explorer
Step1: Attach the memory card to your computer/laptop and press WIN logo key + E to go to Windows File Explorer.
Step2: Select “This PC” option from the left side panel and then search for your card from the right pane by seeing the label and drive letter of your card.
Step3: Now, right click on your memory card and select “Format” option.
Format with Disk Management
Step1: Connect your camera’s memory card to your laptop/computer.
Step2: Launch Windows Disk Management and look for your card from the volume list, then right-click on your card to open a context menu.
Step3: Select the option to “Format..” and then follow the steps as directed to complete the process of formatting.
While if you have data om the card, remember to make backup in advance.
Puntuación 0
Añadir tu respuesta
emilylee2011 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 1,054
