Saltar al contenido principal
Soporte para la serie CQ57 de ordenadores portátiles Compaq.
Preguntas 52 Ver todo
Why is my Compaq presario saying operatig system is missing
Why mypcsaysmissingoperating system
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
There is a good chance that something negative has happened to your hard drive.
I would suggest going into your bios first. (When you first boot the system, hit the button that will give you access, normally ESC, DEL, or an F key)
See if you can locate your hard drive (it may be referred to as HHD).
If it lists the HHD, then you are probably experiencing software issues.
If it is not listed, it is more likely a hardware issue.
I can post additional help after you get to this point, in the comments.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Boss Daddy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 66
