Why does the lens won't operate
Why does the lens of my s860 digicam won't operate as normal?
Es esta una buena pregunta?
i formally had a problem of lens not extending to the normal length on start up. the camera would make two beep sounds and shut down again. I then used my fingers to retract the lens at start up and the camera worked well . afterwards i decided to lubricate the mechanical portion of the lens and since then the camera lens has worked fine. I therefore recommend that once in a while the camera lens should be lubricated with fine thin oil, the type used with sewing machines.
Cheers!!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 2,981
