Saltar al contenido principal
Visual Land Prestige Elite 7Q is a 7" Tablet with a quad-core processor, 8GB of memory, and comes with Android 4.4 (KitKat).
Preguntas 29 Ver todo
Why isn't my tablet working
My tablet wont come on
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
3 comentarios
What have you tried? Charged it? New charger;new cable?
- de
Can you try to describe your problem in detail? What is the situation of your tablet now?
- de
My touch isn't working at all. Power and volume buttons are but no touch???? WATS wrong
- de
Agregar un comentario
3 Respuestas
Respuesta Más Útil
There may be a problem with the battery or charger, check out the Troubleshooting Guide for more information.
Fue útil esta respuesta?
Puntuación 1
Have you tried charging the battery? If you plug in the tablet but the battery won't charge, the battery adapter may be broken. If so, try using a different battery adapter and see if that works. If you have exhausted these options and the tablet still does not turn on, then the problem may be with the tablet itself. In that case, you could try replacing the battery in the tablet because it may have run out of juice.
Puntuación 1
The Reason Is Probably Because It Needs To Be Restarted.
Puntuación 0
Añadir tu respuesta
Tina Stone estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 166
