Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1525 Ver todo
polarity battery iPhone 6
Hello. My battery is dead and I can not start charging.
I want to revive a power supply.
What is the polarity of the battery?
Thank you.
Update (10/25/2015)
Hello.
I've already found.
I share a picture that lets you know the polarity.
The picture is based the motherboard
Thanks.
Es esta una buena pregunta?
Puntuación 2
2 comentarios
By the way.
I made a direct connection to the battery with a charging power supply and has awakened.
The battery fell asleep for being two months without turning on the phone and had 90% load. Very strange.
A electrosock and everything works. :)
- de
Could you help me? So + is the connector closer to the battery?
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Sergio, post a good image of your battery connector with your question. Use this guide for that. It will allow to mark the contacts for you. The positive and negative connectors are the left and right outside connectors. The concern that I have with that, is why you have to do that. Obviously you are having some issues with your phone which you should consider repairing first.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Sergio estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 4
Ultimos 7 días: 24
Ultimos 30 días: 82
Todo El Tiempo: 17,465
