Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
Preguntas 864 Ver todo
Why won't my iPod hold a charge or sync?
My iPod worked perfectly for years...then I dropped it. It broke in half at the seam. I squished it back together and it worked fine. This happened about 4 times. Then I dropped it again. It split in half and this time a little piece of gray plastic fell out. I shoved it where I thought it should go and closed it back up. Only this time it didn't work. The words and picture on the screen were broken up and the blacklight dimmmed then went out. I thought it was gone for good until I got home and plugged it into my wall charger and it booted back up like nothing was wrong. But when I unplugged it everything died. When I plug into the computer it says "very low battery. please wait." But never charges or syncs.
Is the battery just blown or is it a more serious problem?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 0
Comentarios:
It also works just fine when it's plugged into my car charger/player.
por
Agregar un comentario
¡Envío gratuito para todos los pedidos de más de USD100 o que contengan un Pro Tech Toolkit!
Visita Nuestra Tienda
2 Respuestas
Solución Elegida
Just to answer this old question. If it works with it plugged in but does not charge, or quits working when unplugged, replace the battery. Start with the obvious things first, then look for the more complicated and expensive, like a logic board.
Fue útil esta respuesta?
Calificación 1
I would say is the same as this issue: usb device not recognized when plugged into computer
I'm betting for the logic board... but not a 100% sure.
Calificación 0
Añadir tu respuesta
Esther Hamilton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 1,543
