Available from 2013, January. Display - 600 x 1024 pixels, 7.0 inches. Memory - 8/16 GB, 1 GB RAM, microSD, up to 32 GB. Chipset - VIA WM8950 - 1 GHz, GPU Mali-400. Primery camera - 1MP. OS - Android v4.1 (Jelly Bean).
Preguntas 16 Ver todo
What does it mean "Unfortunately, Launcher has stopped working?"
whenever I try to go to a website, I get the message, "Unfortunately launcher has stopped working." Any fix?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 6
Comentarios:
Sometimes my phone will say my launcher has stopped working a d I what it to go away how do I go and do that ?
por
I just had this happen , i had the same problem. You basically have a virus so go to your apps and delete the most recent one you downloaded. It worked for me.
por
You have to do a hard reset because after a while your phone will completely shut down where you cannot turn it off you have to do a hard reset which is pressing the power button and the volume up key and select factory reset and your phone should be working correctly it's going to crash your whole phone
por
What if u need the apps
por
Agregar un comentario
8 Respuestas
Respuesta Más Útil
My launcher has stopped
Fue útil esta respuesta?
Calificación 1
The Launcher is software. Today ALL software has bugs. The biggest single Android issue is the lack of memory management that would permit several apps to run simultaneously without mutual interference,the second is a total lack of clean exit/shutdown requirements for Playstore apps. Many apps, when close by a more recently opened app, will cache data from their last run. This data can easiy become corrupted.
A way to minimize the problems is to accept that Android is not multitasking. Use Developer options to immediately closed Apps moved to the "background". Clear all cache data periodically from Settings/Storage. Restart your device at least once each day, more frequently if you launch apps many times during the day.
Being the only app that runs all then time, the Launcher can be effected by other software overwriting its data, or by a shortage of memory caused by apps not releasing the memory they use.
Before trying extreme measures, uninstall any updates to the Asus Launcher app from Settings/Applications, and do a fresh update of the factory version from the Google Playstore.
Calificación 1
I'm guessing you are talking about launchers on android phones. If so, the launcher usually is considered to be the home screens and app drawer.
​To resolve the error, goto settings -> Apps -> All Apps -> Scroll down to Launcher -> click Launcher -> Click clear cache -> Restart phone.
​Alternatively, you can download another launcher from Google Play. Just search Launchers in Google Play.
Calificación 1
i have a cell phone it a zte phone just got it now i have no services, it says unfortunately, launcher has stoped what does tha t mean and how do i fix it to get my services back
Update (09/20/2016)
i have a cell phone its a zte phone it says on the screen unfortunately, launcher has stoped, how do i fix it and what does that mean
Calificación 0
Comentarios:
por
restart it, it will take it away for the time being. I ran a virus scan and haven't downloaded any apps recently, and this happens to me often, I just restart it everytime it happens and continue with my day, for now, just to be able to use my phone!
por
go to factroy reset and click on that that will work, when you you do that you will have to put all your contacks back in or go to mobile net works click on that then click off your roaming mode that roaming mode will mess up your phone where you cant use it plus you dont need the roaming moad turned on you will see data enabled there should be a green 1 on it leave that a lone
Calificación 0
What does my launcher has stopped on my polaroid tablet
Calificación 0
I have a 44inch black point am TV
Unfortunately ltvlauncher stop working.how can I fix it
Calificación 0
Comentarios:
How do I fix my 44inch smart TV on the screen saying unfortunately,ltvlauncher has stopped.how do I fix the problem
por
Why is my air lancher not working
Calificación 0
Añadir tu respuesta
Eli Shaheen estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 31
Últimos 7 Días: 181
Últimos 30 Días: 944
Todo El Tiempo: 13,133
