Why is my battery life so short?
The battery life in my calculator keeps dying, even after I replaced the battery twice.
Es esta una buena pregunta?
This may be a problem with the solar panel. The solar panel supplies charge to the battery, so if it is malfunctioning then it would make sense for the battery to die quickly. You should probably refer to the Solar Panel Replacement Guide.
Fue útil esta respuesta?
1 stop overcharging
2 get a new cable
3 get a new block
4 use a lower amp charging block
5replace battery
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,418
1 comentario
How long does it last for ?
- de miniarma
