Why can't I use the internet?
My LG G Pad 8.3 says that I am connected to the internet, but I am unable to browse the web. How do I fix this problem?
Es esta una buena pregunta?
Ok! Is this happening only on 1 device or more than one?
If its happening in all the other devices then its obviously an issue with your Modem or ISP!!
If its only your LG G Pad having this issue. May be there is an IP conflict. You have to reboot your modem. If it still doesn't work then you have to reset the modem which will reset the WiFi settings as well meaning you have to reconnect all the other devices as well. Also check your modem how many devices can be connected some are limited to 5 devices at one time or 10 devices at a time. so check how many devices are connected. Hope this helps!!!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 86
