Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3850 Ver todo
Fluttering lcd, sometimes an issue
So, recently, I've been noticing this issue, and it's very recent for me. Sometimes when I install a display assembly, I get fluttering lines, on the lcd. This isn't the same as when you use cheap parts, and you get those white lines. It's almost a strobing/blinking light. All the colors of the lcd picture are there. But they're doing the strobe effect. It's so weird, and I'm getting really good parts. So, I'm wondering if it's something I'm doing? Could it be my magnetic mat? Which Mav ruled out, in a different thread. Anything? Anybody? Oh, I've been getting this with iPhone 5S and iPhone 6
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
Kits de Reparación de Batería de MacBook Air
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
1 Respuesta
Solución Elegida
I have seen this same issue when the LCD Assembly is replaced while the device is still powered on. Make sure you are disconnecting power before you conduct a screen replacement. Also, if your cables aren't connected correctly and you power on the screen it can cause this issue. Hope this helps! Keep us posted!
Fue útil esta respuesta?
Calificación 0
Comentarios:
I could see the connections not being properly seated, as the result. Thanks!
por
Añadir tu respuesta
iMedic estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 5
Todo El Tiempo: 90
