Lanzado en Septiembre 19, 2014, este iPhone con pantalla de 4.7" es la versión pequeña del iPhone 6 Plus.
Preguntas 4267 Ver todo
Touchscreen not responding, even after LCD/Touch replacement OEM
So i have encountered some issues with iPhone 6 and iPhone 6 Plus.
The touchscreen will freeze and to me make it work again i need to restart the phone, i thought the issue will get fixed replacing the LCD/Touchscreen assembly. But it persists. The chasis was a little bent and also thought this is causing this issue, but even after straighten the issue persists.
What i have done and haven't fixed my issue:
  1. Replacing the LCD/Touchscreen assembly (aftermarket)
  2. Swapping the LCD/Touchscreen assembly from a functioning iPhone 6 to this one
  3. Straighten the chasis
  4. Have the inner chasis covered with thermal tape
  5. Restoring the the iOS
Does anyone have encountered this issue? And knows how to fix it?
Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
I have the same problem: Touchscreen not working - even after screen replacement
Might be something called "touch disease": Touchscreen Periodically Not Working
Fue útil esta respuesta?
Calificación 0
Common issue. It's Meson IC, you need to reballing.
This rework requires high skills and professional equipment.
Calificación 0
Añadir tu respuesta
Robert G estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 139
