Saltar al contenido principal
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
Preguntas 59 Ver todo
VCR won't load cassette. Cassette doesn't drop down when pushing it in.
Hi,
I have a Toshiba V-804G VCR that no longer loads cassettes. I removed the lid, and can see that when I push in the cassette, it doesn't go down all the way. The gears of the white part on the right in picture 2 turn and make noise, but don't seem to do anything. The mechanism at the arrow tip in picture 4 doesn't go down around the corner as it should to drop the cassette into place.
We've had this VCR for a long time, and I'd like to get it working again, especially because it can play both PAL and NTSC tapes, and we have quite a selection of both.
Any repair tips would be greatly appreciated. Thanks!
Es esta una buena pregunta?
Puntuación 2
2 comentarios
P.S. I speak English and German.
- de
I can not load a vcr tape into my vcr
- de
Agregar un comentario
4 Respuestas
Solución Elegida
rickfilms, check the loading motor sensors etc. See if this will help to get started:
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Did you manage to finally solve it? I'm having the same issue..the icon at the display tilts as if the vcr already had a tape inside, but so far this is all I could find out..
- de
Hey, it's possible that the mechanism skipped when unloading the last time, this means that things are happing at the wrong time. Does it sound as if it is jamming? the other thing to check is if there is a belt drive below it, I know they stopped using belts for this use, but maybe this one has one in there.
When faced with this I would have turned off the power and manually turn the small wheel to see when it stops, that is another this ti t ry.
Good luck
Puntuación 1
What I did with my digital samsung VHS , was literally hold the tape down until the light comes on (whenever a tape is inserted, I also removed the top off and screws but and pop it on/off).
after a couple of seconds, the VCR detects a tape in and the tape itself goes thru the motions (gears , head).
then I play it, but it may eject/stop/rewind a little but after 5-6 times or more (keep putting tape in and holding down) it'll eventually play. But this has to be done each time.
Puntuación 0
Please help i have the same problem and i really want too watch some vhs on my crt :(
Puntuación 0
Añadir tu respuesta
Rickfilms estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 26
Ultimos 7 días: 106
Ultimos 30 días: 320
Todo El Tiempo: 40,789
