Saltar al contenido principal
Modelo A1311 / Mediados de 2011 / Procesador Core i5 de 2.5 y 2.7 GHz o Core i7 de 2.8 GHz
How reconnect display date cable?
When reconnecting the display data cable to the logic board on an EMC 2428, is there a trick to lining it up correctly? I assume that the connection is made by inserting the male cable to the female socket on the logic board by sliding it towards the top of the machine (the reverse of the disconnection), yes?. But I cannot get it to seat in the socket. I would hate to damage it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
The only issue one faces is putting the plug in backwards. You may want to take some colored tape to mark across the connector & cable to help remind you which face is outwards.
The alignment is straight in and the wire bail holds the connection.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
dickson estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 312
